Also, 4.)I would like to understand better how much power/performance it would add to my car.
Would it wear down and burn out my engine?
If i could find an inexpensive one and install it inexpensively, I would do it.
Well, if you can find the parts you can do cams, high compression pistons, header etc but that's a ton of work and the labor is way expensive and the parts aren't cheap IF you can find them.ScottyK wrote:oookaaaaayyy.....what are other methods I can use to increase hp?
If you could find a clean running Boosted Honda for under 5k, chances are good it's either a D series, or has a ching chong meow turbo kit on it.Monkey-Gein wrote:yeah. you could get a boosted honda for under $5k. parts are cheap and there's a big aftermarket out there for them. you could prolly have more power then a focus is capable of. and there's a great mn community for them
I actually have a generic 16G for sale!KRYPTO wrote:you could do a cheap turbo kit you put together using a small turbo off a DSM, Vovlo or something that has a small turbo. Then not much to worry about for over power and what not.
