So I was looking around at what I needed to do for my suspension tomorrow and well, I have a sway bar already in there being my sedan is an SE.
So what is the difference between my sway bar, and the SVT sway bar?
Because those bolts are gunna be bitches to move and I'd like to know if I should bother or not becasue the size looks the same to me, but that is just eyeing it up.
-Nick
SVT sway bar -vs- Sedan SE sway bar
Malibu Blue 2001 Focus Sedan SE
Ford racing plug wires, Volant CAI, Focus Central UDP. FC 65mm TB, MBRP cat-back w/ Focus Sport Stealth Resonator, SVT Header/Cat/Flexpipe, SVT Suspension.
replying to myself, did some research and the stock bar is 20mm, and the SVT is 21mm.
-Nick
-Nick
You might want to start soaking all that hardware with liquid wrench if you are going to try to re-use it. Or buy all new before you get started because you will probably break some.
