Dog bone motor mount?
STANG302
Whats the easiest way to install the new polly inserts in the dog bone trans mount?
STANG302 wrote: Whats the easiest way to install the new polly inserts in the dog bone trans mount?
I took mine to the shop and had them press them in, if I had a vice, I'd burn them out with a torch, wd them, and crank until they start to slide in and then use a bolt w/ a nut and a larger sized washer to push it in the rest of the way.
Shop said they charge a min of 1/2 hr labor, which was $33, I took it to the chevy dealer, only ones open.
98gsxltd
i used a vice on mine & it worked.
STANG302
I got it done tonight took me longer than I figuired. With no vice I ended up burning out the small oval bushing. For the other end I used fence post mall witch had a perfict ID to use a punch and hamered it out. Wasn't to bad just had to improvise on a few things. Also cleaned off all the road grime and gave it a coat of paint and slip the new bushings in with out any problems. I will be installing this friday on my ST got any recimendations for that?
Its cake and fairly strait forward.
MAT
So how'd it go? I am thinking about just doing the big one myself...
MAT
Roberts, WI
05 ZX3 SES Infra-red (It's hot!)
Mods: Crane Stg 1 cams, F2 Header, Marcy CAI, Borla cat-back exhaust, FocusSport ECU tuning, SVT suspension, 17" FRPP rally wheels
(I'm just getting warmed up!)
STANG302
MAT wrote: So how'd it go? I am thinking about just doing the big one myself...
Install was a piece of cake maybe took me five min total to get the old out and the new one in. Lining up the bolt holes was the bigest pain. And the vibration some people complane about realy isn't that bad even with the ac/defrost on. Honestly I recieved more vibrations from the BS delete that I did with these bushings. All in all probobly the best mod I've done.
