Engine Swap!
- Car: 1995 F-150, 83 GTI
Has anyone ever heard of doing the CSVT engine swap with the Focus, sedan, wagon, or hatchback? I've heard ppl talk about it but never actually seen it. Does anyone know anything about it?
It's been done. I toyed around with the idea when my motor popped last summer.frankjt96 wrote:Has anyone ever heard of doing the CSVT engine swap with the Focus, sedan, wagon, or hatchback? I've heard ppl talk about it but never actually seen it. Does anyone know anything about it?
There are no 'kits' to do it though. It takes a TON of fabrication (motor mounts, tubing, wire harness work, etc.) The wiring has to be completely re-done, recute and splice pretty much the entire wire harness etc. Not any great way to get it tuned either.
Possible, but hard. Also there is no room left in the bay to ever do anything else to the motor.
I figured it was cheaper to swap in a fresh zetec block and add boost for the same power and the ability to add more if I needed/wanted.
trahma
- has a blownup bomb
- Car: 2002 Malibu Blue ZX3
There's a reason only 3 swaps were ever done like this. Like Pappy said it's a ton of work to do the swap. ZX3Tuning originally was trying to create a kit based on their yellow car but in the end figured it was far too expensive to try to create the kit and market it.
reconstruction.
Might as well drop in a v8 while your at it and convert it to rwd
Here we go again....
I don't know what you're talking aboutSVT-swap wrote:I would advise that you stay away from that engine. Any repairs on that thing suck.
I thought it was Yamahao2designs wrote:Yeah, its a pain in the ass swapping in that Mazda motor...
haha
Yeah, the Yamaha with 2 T3s hanging off it make a great engine in an XR4Ti...
Focus: singular
Foci: plural
Not interchangeable
Foci: plural
Not interchangeable
just go with the svtf swap, you only need to cut at the fuel pump ,then yank the harness out, put in the svt harness,change a few connectors,get rid of the abs crap( unless you have abs already then its easier to leave it) bolt it all to gether slam it with 8 psi and a good tune and clutch, and have fun with your 300 horse svt zx3 hybrid.
