grille idea
cant_focus
Car: 2006 liquid grey hatchbac
playing around with photoshop today. the plan is to just shade it dark with like nightshade or something like that...maybe ill just go with color matched...gimme your thoughts
Jordan
Nightshade on chrome could be a disaster. Pretty sure you could sand it down and paint it though. I like the 2nd pic... looks wierd badgeless
focus_SWT
Dupli-color clear primer, and then smoke dupli-color metalcast.
You can't just paint over the chrome. It won't stick. You'll need to steel wool or scratchy pad it, then paint it. And you'll need a primer to even stick to that. Like a plasitc primer.
I'm not saying it won't work, but I am saying " I told you so", and you'll have a disaster at hand with smoke.
Besides, a color matched LG grille with silver mesh would look better anyway.
Painted my Chrome grill Red, sanded it down with 400 so every inch of it was roughed up then cleaned the surfaces with acetone used duplicolor primer then paint. I haven't finished it yet I will need to do some in between coat sanding then clear and final paint finishing.
grocerygetter wrote:Painted my Chrome grill Red, sanded it down with 400 so every inch of it was roughed up then cleaned the surfaces with acetone used duplicolor primer then paint. I haven't finished it yet I will need to do some in between coat sanding then clear and final paint finishing.
Should look good on your car...
But like Brian said, you need to sand that chrome off. And if you do that, your gonna lose the Hyper Black finesh your after. Just shoot it Liquid Grey.
cant_focus
I might just paint it black..I kinda like the look...if it ends up bad i'll just buy a color matched one.
Jordan
Car: 1995 F-150, 83 GTI
do like we did with the bimmer, don't prep it, clean it, or anything. just paint over the chrome part while the grill is still on the car, without anything tapped off of course! :lol: god that turned out like crap
Doesn't look to bad. They both look good! 8) I agree that a color match would look good also.... Headlights to mybe...
i still need to pull mine off and do this...
