eh, what the?
- Brake-Late
- Car: pitch black 03 svt focus
so i poped my hood today becuse my brake light started flickering under throttle and cornering, so im guessing the fluid is low, and it is along with all the rest of my fluides. not like empty but all near the low lines, they where fine around a month ago. so i find it a little strange that they all droped. anyway i need brake fluid, power stearing fluid and antifreeze.
Mine does the same thing, actually constant under hard accel. It's because the ebrake cable is full of moisture and froze a bit, not completely but enough that it can not properly stretch and move. Nothing to worry about for me really. has happen every winter since new, so 8 years now.
You could try loosening the cable some, might help. Or maybe your rear shoes are just wore that far down.
- Brake-Late
i just did rear pads and rotors about two weeks ago. you dont think its the fluid level? huh, i find my focus to be strange and confusing
- Monkey Gein
- Car: 07 Silver ZX3/07 Black ZX
- Brake-Late
i gots a 03 svt. i noticed the power steering fluid was a little low last oil change but the coolent and the brake fluid thing was a bit suprising. i should really spend some time going through everything on the car soon
You may have a leaky t-stat housing which would explain the coolant thing.
Another relatively common issue is a leaky clutch master cylinder, look up under the dash directly abouve the clutch pedal and see if it's leaking.
Brake fluid level drops as brakes wear out but when you do the brakes and push the pistons back in the fluid goes back to it's normal level.
Theres really no reason to EVER add brake fluid to the system in normal use, if it's low theres a reason for it.
What about the smell of antifreeze out the exhaust everytime you start the car up?
- Brake-Late
see i know this about the brake system and that is my main concern, the coolent im not to woried about power steering is another one that bothers me...they are all sealed systems and really should not be low...they work fine and the car has no drivabilty problems... its seems to coinside with that last cold snap...i really hate driving my cars in the winter....FORDSVTPARTS wrote:You may have a leaky t-stat housing which would explain the coolant thing.
- KRYPTO
- Car: 02 race car red SVT
Yeah, I had my master leaking down the pedal. You should be able to tell easily.
Another thing (just throwing it out there) they may go down alittle by being cold out???? if that makes sense (cold shrink, hot expand)
Thats only on your SVT.Patalrob wrote:What about the smell of antifreeze out the exhaust everytime you start the car up?
Did you check the PS hot or cold?Brake-Late wrote:see i know this about the brake system and that is my main concern, the coolent im not to woried about power steering is another one that bothers me...they are all sealed systems and really should not be low...they work fine and the car has no drivabilty problems... its seems to coinside with that last cold snap...i really hate driving my cars in the winter....FORDSVTPARTS wrote:You may have a leaky t-stat housing which would explain the coolant thing.
- Brake-Late
i checked everything when i got home, so hot
im a total noob with this focus so i dont even know what is normal...i work for toyota and info on fords is is hard to come by even more so becuse of the svt part....
heres the deal... the clutch master is fed from the brake resivior, i had this issue a few months back, as the master leaks the fluid drains from the brake resivior. the cold will make some fluids contract but they should go back to normal after they warm up. but on the other hand as it cools the rubber hoses contract wich would cause the level to rise so who knows, i only work here.
wink wink.....bitches- Brake-Late
yeah it is the clutch master...now to see if i can get it done under warranty, so for now it will sit till monday
- grocerygetter
- Car: 2006 Infra Red X3
It's tough to turn the key with your nose stuffed up the tail pipe...hehehePatalrob wrote:What about the smell of antifreeze out the exhaust everytime you start the car up?
