I'm looking to get another E30 so that means the Jetta has got to go. I'm looking to se if there is any interest. 1986 Jetta, odo. stopped at 83K but has under 90K on it. Only rust is where the paint is chipped away. a few dents, one along the pass. side of the hood, and one along the pass. side of the trunk, one on the center of the front of the hood, and on the roof right above the window. good glass all around, brake light on, brake pedal soft, e-brake is weak, and rear defrost doesn't work. the drivers rear door doesn't open at all, and the front pass. doesn't open from the outside. handle just needs to be tweaked with. no rust underneath, or on the strut towers. 5spd manual, good clutch, 1.8 8v motor. Looking for $600
