Steve,
What is the current SVT Disc brake upgrade kit going for? Have any Idea on what install time is like?
Thanks,
Brian
SVT REAR BRAKE UPGRADE KIT PRICE
- grocerygetter
- Car: 2006 Infra Red X3
Install time? I guess it depends on who's doing the install
I really haven't got a clue but as long as you don't have issues with nuts and bolts it should be easy enough to do in a day, the fronts should be a breeze on your car since it's just calipers and rotors.
Front kit $302.50
Rear kit $429.00
I have both in stock.
Front kit $302.50
Rear kit $429.00
hey just for S and G's do you know the dimensions of a mazda 3 hub, you know the part you you press into the wheel bearing? and do you know the inside diameter of the svt wheel bearing? hmmmmmm almost makes a 5 lug converstion with big brakes sound tempting huh?
Did you spend a lot of time working on Mazdas when you were here?focinite wrote:hey just for S and G's do you know the dimensions of a mazda 3 hub, you know the part you you press into the wheel bearing? and do you know the inside diameter of the svt wheel bearing? hmmmmmm almost makes a 5 lug converstion with big brakes sound tempting huh?
Swing on by with your micrometer and I'll let you measure the Focus hubs and bearings, Polar Chev Mazda is right up the road
