Is there anybody in the south metro that can come over and put my dsi lever on,I will give you 20$ for your troubles.
I can slip the lever on and off I just can't get the spring part to work.
I would drive the car to the dealer if I could get the dsi motor to stop working
dsi help
I'd do it for you but you'd have to drive to me in Shoreview, I'll be working here at Tousley tomorrow from 9:00 am to 1:00 PM as well.nemo wrote:Is there anybody in the south metro that can come over and put my dsi lever on,I will give you 20$ for your troubles.
You can drive the car with it unhooked, just unplug the DSI acutator and make sure you wrap up the connector and socket on the actuator real well to keep moisture out.
nemo wrote:how do I unplug the dsi motor
Just follow the sound, it's under the drivers side front corner of the car. If you lay on the ground and look under the corner of the bumper cover you'll see it there.
It's like any other component, just find the wiring and unplug it.
Keep in mind that you will get a check engine light if you do that but the car will run just fine and the light will go away after you plug it back in if you just disconnect the battery for a short time to reset the ECU.
Late to the party...What's a dsi motor and how will it improve mileage?
Paul
DSI= Dual stage intake.PBZX3 wrote:Late to the party...What's a dsi motor and how will it improve mileage?
It's on SVT's and he's leaving his unhooked which means he's running on the high speed runners at all times.
aahhhh, now I understand.
Paul
i dont, why would f-ed up fuel trims allow you to get better mileage? dont that thing bog like a pig down low? all that black smoke is not a good thing.
pumping loss? the only way i could see mpg improvements are if it was running leaner than normal, but this is bad cus the cossie engine in the st170 is of higher compression and that plus lean equals hole in pistion.nemo wrote:I don't know ,maybe less pumping loss,maybe the fuel and air mix better.
I'm only 40 miles into a new tank, so I'll report back if I turn some big numbers.
