So my trusty ol sedan (bone stock 02 ZTS) threw a CEL today. I pulled the codes and I'm getting codes for both o2 Sensors..... I cleared the codes, drove about 3 miles and it came back on again.
The car is acting completely normal and is running completely smooth (which I don't think it would if that Bank 1 o2 was actually failing).....
I'm having a hard time believing they both just magically failed at the same time, together.
Any ideas what else could be causing this?
O2 Sensor Fail?
My 2000 has both codes on ATM also. I haven't yet changed o2 sensors but I have heard of them "magically" going out at the same time. Mine does run fine the idle is doggy under hard use "A/C, P/S" Gas mileage is crap in town.. I suppose I should just give it a full tune up...
You're correct it's blowing the #18 fuse, so there is a short somewhere I need to find.
Thanks
Thanks
