Anybody have a boost mtf file for SCT just to use as a base?
Strubmotorsports
- Car: 2003 Ford Focus ZX3 SC
just need a new baseline to tune from
Graphite ZX3 VFstage 2 Supercharger intercooled, Crower stage 2 forced ind cams, Crower Valve Springs, 9:1 pistons, Fidanza timing gears, Eagle Rods, Extensive Head porting and machined, 9:1 pistons, Fidanza timing gears, Eagle Rods ect..
MTF as in Mass Air Transfer Function?
Or do you need a base tune in MTF format?
The Mass Air doesn't change until you change injectors.
Here is a base file for ECU Code JFA7 --> https://drive.google.com/file/d/0B4sorV ... sp=sharing
Here is a base file for ECU Code ZYF5 --> https://drive.google.com/file/d/0B4sorV ... sp=sharing
I'm not sure if either will work for you though, and any risk is up to you and you alone.
Strubmotorsports
Thanks yes I was looking for a Mako Tune File, I will look through and see what I can learn.
