Trying to find the specs on my SVT block/internals. Looked on the net and came up with nothing detailed enough. Anyone know what they are or where I can find them.
Thanks
Zetec specs
2.0L Focus Zetec DOHC 2000
Horsepower (stock) 130hp @ 5300 rpm
Torque (stock) 135f/p @ 4500 rpm
Compression Ratio 9.6/1
Cylinder Bore 3.339
Crankshaft Stroke 3.465
Connecting Rod Length 5.3618/(97 5.4820)
Valve Diameters (Int/Exh) 1.260/1.100 (2 Int, 2 Exh)
Throttle Body Diameter 55mm
2.0L Focus SVT DOHC 2002
Horsepower (stock) 170hp @ 7000 rpm
Torque (stock) 145f/p @ 5500 rpm
Compression Ratio 10.2/1
Cylinder Bore 3.339
Valve Diameters (Int/Exh) 1.319/1.102 (2 Int, 2 Exh)
Throttle Body Diameter 66mm
Main diff between ZX3 Zetec and SVT Zetec is the head with Variable intake cam timing, a dual-stage intake manifold, tuned tubular header with a more free flowing cat and exaust, a dual-mass flywheel, i think thats about it for the intake/exhaust side.
internals have forged connecting rods, and 20mm wrist pins and of course different pistons to increase the compression.
more info here: http://myfordfocus.com/svt/
Cylinder Bore 3.339
Cylinder Bore 3.339
- KRYPTO
- Car: 02 race car red SVT
I know all that. I'm looking for what it can handle. rpm's rods ,crank, etc...
Are they froged pistons, crank, etc...
what type of rods I or H?
Whats the weak spots on it?
Valve lift, cam deg., etc..
That type of stuff. The main specs
crank and pistons no, rods yes. Type no clue, never seen the info on that. Call or Email Mcnews http://www.mcnewsautomotive.com/ they're probably the best all around SVT focus experts out there.
And, from all accounts, they are very helpful.umdivx wrote:crank and pistons no, rods yes. Type no clue, never seen the info on that. Call or Email Mcnews http://www.mcnewsautomotive.com/ they're probably the best all around SVT focus experts out there.
If thats the kind of stuff you wanted to know in your PM then I can't help much.KRYPTO wrote:I know all that. I'm looking for what it can handle. rpm's rods ,crank, etc...
Outside of advertising Ford really doesn't tell us anything like that.
The manuals are only there to assist in repairs and the parts book only gives part numbers, it doesn't tell us that the pistons are cast or forged. In fact my Ford resources don't even give cam specs because in all reality in the parts world it doesn't matter. Ford says this is a Zetec cam and this is an SVT cam.
They don't even publish acceptible cylinder pressures for a compression test.
