What's it worth?
- Cajun Mafia
- Car: 01 Street Wagon/02 ZTW
I ran across someone selling a zetec head. It's basically rebuilt, shaved .035 (+.5 compression bump), chambers cc'd, exhaust ports polished, FR oversized valves, high lift springs/retainers, and crower stage 2 cams installed (correct buckets installed). The head has less than 100 miles on it. The guy is asking for $650. Obviously the parts are worth the price and the machine work has value too. $650 sounds fair. Is this too much, just about right, or not enough (ie..a good deal)?
- grocerygetter
- Car: 2006 Infra Red X3
How does the price compare to the retail market? Have you checked out the larger Foci parts dealers to see what a refurbed/upgraded head costs?HotRodWagon wrote:I ran across someone selling a zetec head. It's basically rebuilt, shaved .035 (+.5 compression bump), chambers cc'd, exhaust ports polished, FR oversized valves, high lift springs/retainers, and crower stage 2 cams installed (correct buckets installed). The head has less than 100 miles on it. The guy is asking for $650. Obviously the parts are worth the price and the machine work has value too. $650 sounds fair. Is this too much, just about right, or not enough (ie..a good deal)?
- Cajun Mafia
I have seen rebuilt stock heads go fo $300. This is looking like a pretty fair deal.grocerygetter wrote:How does the price compare to the retail market? Have you checked out the larger Foci parts dealers to see what a refurbed/upgraded head costs?HotRodWagon wrote:I ran across someone selling a zetec head. It's basically rebuilt, shaved .035 (+.5 compression bump), chambers cc'd, exhaust ports polished, FR oversized valves, high lift springs/retainers, and crower stage 2 cams installed (correct buckets installed). The head has less than 100 miles on it. The guy is asking for $650. Obviously the parts are worth the price and the machine work has value too. $650 sounds fair. Is this too much, just about right, or not enough (ie..a good deal)?
- grocerygetter
Looking out on the net just because I am curious about it prices vary a bit but something similar to what you are describing I have found that the labor on the head to be within the range of $800 to $2700 (the last being on a Subaru Legacy GT, and of course they have two heads instead of one). The port and valve jobs were being sold as a "street" up to "stage 2" performance work.HotRodWagon wrote:I have seen rebuilt stock heads go fo $300. This is looking like a pretty fair deal.grocerygetter wrote:How does the price compare to the retail market? Have you checked out the larger Foci parts dealers to see what a refurbed/upgraded head costs?
I would say that for the price IF the machine and bench work that was done is quality work its worth it, if not you have a bunch of performance parts bolted to a boat anchor.
