Mon Jun 30, 2008 8:47 am
Mon Jun 30, 2008 11:23 am
First two, overlook in OakPark Heights/ Still-H2o Border.
Last one still-h2o lift bridge yo.
I win
Pics are sick tony.
Posts: 3305 Joined: Tue May 02, 2006 7:36 am
Mon Jun 30, 2008 11:43 am
Bingo
Man it was crowded down there yesterday.
Mon Jun 30, 2008 2:48 pm
Have you ever been pulled over with that plate there?
How much ground clearence is under the right side skirt?
Mon Jun 30, 2008 3:10 pm
o2designs wrote: Have you ever been pulled over with that plate there?
Not yet.
o2designs wrote: How much ground clearence is under the right side skirt?
One pop can roughly. Oh, and the left side skirt is roughly the same.
Mon Jun 30, 2008 3:15 pm
Is the front the same height as well? I've always wondered...
Do you use a short shifter? And if so, does it retain the reverse lockout?
Mon Jun 30, 2008 3:17 pm
Front of the skirt is slightly lower than the rear. The pop can (mountain dew in case you were wondering) fits with a slight air gap under the rear of the skirt, whereas in the front it doesn't quite slide under.
I use a Focus Steeda short throw. It retains reverse lockout but breaks shift cables
Mon Jun 30, 2008 3:24 pm
Oh nice...its just slides in without modifing it?
For your exhaust, does the y-pipe bolt togher after the rear subframe, or is it one piece?
Mon Jun 30, 2008 3:34 pm
Yup slides in, I had to lift the tower in the car just a bit so the longer bottom half of the shifter had clearance. I did it with a piece of plexi-glass I cut out to fit the size of the tower.
The exhaust is one piece after the catalytic converter. The y in the rear is welded in.
Mon Jun 30, 2008 3:51 pm
Cool...
Are your windows tinted. They look super dark...
What kind of air filter you have? Any gains from it?
Mon Jun 30, 2008 3:52 pm
25% window tint.
Psssh K&N son, added like 50+ whp too.
Mon Jun 30, 2008 3:55 pm
Oh nice...Stock MAFs?
Any subs? What kind of ICE does the Contour have?
Posts: 3559 Joined: Sat Dec 15, 2007 11:08 am
Mon Jun 30, 2008 5:20 pm
Nice Pix! Where is that over look in OPH? I have been at the MCF for 3 weeks now doing some work there again.
